Curing of Masonry Walls Question
I designed a 18'-0" high, 12" masonry wall. The inside is protected from the elements and the outside is not (Michigan -45 degrees +-). How long should it cure before placing roof joists on them?
RE: Curing of Masonry Walls Question
