Tie Wire
Tie Wire
Tie Wire
I am currently working on some interior metal stud framing.  The framing is suspended from the metal deck above around the perimeter.  The contractor is utilizing 12 gage steel tie wire (@48" c/c) to help support/ suspend the interior ceiling members.  Does anyone know the allowable tension for this tie wire?
RE: Tie Wire
Supplier or mfg should be able to provide this info...
