Rockwell Hardness B Values for A356-T6 Casting
I have an A356-T6 casting that was repair welded and stress relived per AMS 2771. The AMS spec sends you to the material spec which provides Brinell values for process verification coupons. I only have access to a Rockwell B hardness machine and can't find a conversion factor from Brinell to A356 casting.
The AMS conversion spec provides Brinell to Rockwell B for Wrought aluminum but not castings. Is it acceptable to use these values or can someone point me in the direction of the correct conversion or actual Rockwell B values?
RE: Rockwell Hardness B Values for A356-T6 Casting
