DWG sizes for torsion springs
Hi!!!
I´m looking for standard worldwide sizes for torsional, compression and tension SPRINGS. Under what standard and where can I find those sizes and/or dwgs???
Thanks!!!
Roland
Thanks!!!
Roland
RE: DWG sizes for torsion springs
However, every standard publishing organization has a web site and they all have search functions.
Most spring manufacturers have web sites with on-line catalogs. If their springs are manufactured to a standard, that should be identified in the literature.
Let us know what you find out.
Here is an online typical website you can look at for all type of springs but these springs or not standard worldwide they are just one companies range of springs.
However they also quote various specifications that the spring wire is made from and tested etc, there is also reference to a specification for designing such springs.
http://www.leespring.co.uk/pages/home.html
desertfox
Also, if you get into a pinch, there are several good websites that offer spring calculators to meet your needs. EngineeringEdge is one of those, probably one of the better ones.
Go the commercial available route, much cheaper since pieces are immediately available in massive quantities. This addresses future needs such as redress kits.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
