Does anodization provide good insulation?
I know it typically blocks a decent chassis ground connection for a screw terminal. You have to mask the terminal off before the part is anodized, scrape through the coating afterward, or use a star washer to 'bite' through it.
Is it a reliable insulator though? Has anybody seen any specs on the resistance?
John D
John D
RE: Does anodization provide good insulation?
TTFN
I have used this before with great results on laminated bus bar applications,etc... ht
John D
www.MaguffinMicrowave.com
Maguffin Microwave wireless design consulting
