"Rectangular Instance feature" associative orientation
Hello All,
I recently updated to NX5 and I 'm so surprised to see that NX5 still does not have associative orientation control for XC & YC direction in the rectangular instance feature.
It wouldn't be too much to ask for the instances to follow the orientation of a lead-feature would it.
Especially since it's been on lots of UG-wishlists for ages.
Or am I missing something.
Ronny
RE: "Rectangular Instance feature" associative orientation
Try using pattern face more often.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Hello Hudson,
Thanx for your Re:
I am aware of the alternatives ( Pattern Face and Instance geometry) and they all have their merits but in my modest opinion , using it as a workaround for "instance feature" doesn't always work for me.
For example ( and these are quite simple examples)
-a pattern of hole features with " pattern face" won't update if you change the leading hole from simple to counterbore,
nor will a blend all instances work, etc , etc,...
Using the alternative only disguises the fact that instance feature isn't up to scratch.
It' s one of the few thing where associativity isn't implemented completely and I don't see way it shouldn't be possible.
Don't you agree?
Best Regards
We are aware of this issue and it is being addressed as part of a larger, more comprehensive project designed to consolidate and improve the 'patterning' capability of NX, be it features, objects, components, etc.  Note that this will be a multi-release project, with the first deliverable based on the new architecture being the ability to create an 'array' of curves inside a Sketch.  This initial functionality will be included in NX 7.5 with the other types of 'patterning' tasks being addressed in subsequent releases.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Ronny,
I think your main beef with it should simply be that the associative component instance arrays don't work.
As John has commented and/or mentioned elsewhere all of that may be hopefully addressed in NX-7.5 and beyond.
Best Regards
Hudson
www.jamb.com.au
@ Hudson : Indeed the ISET array is another issue but one that doens't affect me much in the work I do
@ John: Good to hear the issue is being worked on, although I fear it will be some time before I get to enjoy the enhancements since we follow the GM NX version.
The "array of curves inside a sketch" would also be a great enhancement in my opinion. I do a lot of perforated pipes and plates , it would be great for that I guess.
Best Regards
