fit command problem
fit command problem
fit command problem
I've a very weird problem.
We recently changed from NX5 to NX6 and now my "fit" command doesn't work anymore with some assemblies. Doesn't make any difference if I use the fit from the pull-down or control-F or the fit on my space pilot.
When I do "Fit" my whole assembly disappears from the screen. With end or home I get it back.
But when I click with the RMB anywhere in the screen I can sometimes select a part, so it is seems to be there but I can't see it!!
It's very anoying since it also recalculates the boundaries of the assembly when doing a "fit".
The UGS helpdesk did there best but couldnt find it.
PS. A fit on the same assembly by a colleage just works well!
I use NX5.
Groeten, Michel
www.kvi.nl  A leading Dutch institute in atomic and subatomic physics
