blocks in viewports
blocks in viewports
Hey everyone
This is kind of strange but i all of these stop signs placed in the right area ( they are blocks). Now when i am in model space they are showing up. But when i tile over to paper space and inside the viewport they are not showing up. And only way to have them show up is if i explode them. Now they layer is on, not frozen or locked. Is there any other way to have them show up other than exploding them.
Thanks so much for any suggestions
Juice
( im in acad 14)
Juice
( im in acad 14)
RE: blocks in viewports
From the symptons you provide it does sound like a 'viewport freeze' issue. When you explode the blocks I'm thinking that the lines revert back to their original layer when the blocks were created (probably layer '0') and layer '0' isn't frozen in the viewport in question, hence you see them when exploded. Naturally, when you are in tilemode 1 (modelspace) you'll see all the layers as they are only effected by the normal 'freeze' command in here and as you've stated these are all turned on already.
Hope that helps.
Marc
