Max Deflection on a Beam
Hello, I was wondering if someone could help out.
My problem, need to find the max deflection along a beam with a center load of 500lbs. The beam is a typical I beam I4X13, that will be braced at both ends 17 feet above the ground. The Ixx = 11.3in^4
Iyy = 3.86in^4
Hoping to see the calculations to better understand it myself.
Thanks!
Iyy = 3.86in^4
Thanks!
RE: Max Deflection on a Beam
If this is an assignment then very few engineers calculate deflection from first principles, we mostly tend to use deflection formulii such as those found in the back of steel designers handbooks.
Also, your beam will be a lot stiffer if it is deeper, even at the same 13 lb/ft weight. Just something to consider.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
BA
