Repeat Region
Repeat Region
Repeat Region
I need to make 3 repeat regions that sorts items into 4 different Part_Type. Part_Type being a user defined parameter with allowable input of: Purchased, Make, Standard, Spare Part, and Null. The null value being inclueded to filter any Items that I need to exclued completely. The tables should populate each of the 4 tables based on another user defined parameter called Order_Code. This will allow me to name the components in the stocklist correctly, (no underscores and other limitations of part files like no spaces). I would like to make the listing stable in each repeat region so that if a component is removed that index number will stay empty and not renumber all the balloons.
 Maybe it is just me but the repeat region index allong with it's filter menu is confusing at best. The difference between asm.mbr.name, asm.mbr.value, asm.mbr.param.name, &, no &. The documentation on this is not much help.
1) Any help with these regions would be great.
2) PTC needs to make the report features of Pro more user friendly. (IMO)
Thanks in advance
