LM Tools Server Status query
We have NX3 running on one server and NX5 running on a seperate server. If I do a server status query to see which licenses are being used it looks at the NX3 server. is there a way to change the server that it is looking at? We've tried looking around, but can't seem to find anything.
RE: LM Tools Server Status query
I think that the first (Server/License File) tab shows the server you're running, and the Config Services tab allows you to change what server/s you're pointed at. Technically speaking you can have more than one server running at any given time, and if you do so the checks you perform under the Server Stats and Diagnostics tabs should list for all of them. It may just be a matter of scrolling down the list to check all of the diagnostic output.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
