How to print in color
Can somebody help me how to print the views in color? In the draft file all views are fine but when i print only text and dimension are colored.I'm using ST2 i don't have this problem in ST1.
Intel Xeon
Fire GL V7350
Intel Xeon
Fire GL V7350
RE: How to print in color
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
does the problem exist for shaded views only? The this might help
Below this registry key
HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version 102\DEBUG
insert a new key (when not there)
Type: Dword
Value: 1 (the value can be either 0 or 1)
and see whether it solves. (I think in V100 and below the value was set
to 1 when the key was missing from the DEBUG section)
dy
With V100 and below I had to insert the key with a value of 0.
Now I can delete this they and printing is still OK. So I think
they changed the default to 0 which might lead to problems with
those printers that did work before. This 'switch' has something
to do with a technique called 'Bit Masking' to avoid overprinting
of views were one view area hides the other. But not all printer
driver can handle this ...
dy
