XY-graphing in Motion
Hellow
Is there a possible solution to my problem?In the motion environment i want to have a graph. I want to define the X-axis to another variabele instead of the time. I would like to use the displacement. I already found out that you can push the user-defined button and after that you can load a X-axis such as the displacement. But when i push the OK-button i have to seperate graphs instead of 1. Both are dependent to the time. Is there a way to solve this problem?
thanx
thanx
