Flow Calculations
Flow Calculations
How do I calculate for the following:
Two phases of flow (water and air runned in an incline pipeline from point 1 to point 2. Point 1 P1=200psig, T1=180F, Q water=300GPM, Q Methane=300ACFM.
I need to calculate Q water, Q gas actual ACFM, and Q gas standard SCFM. at Point 2 assuming P2=50psi and T2=175F ??
How would the calculation change if instead water, oil were flown?
RE: Flow Calculations
If you're after the flow regime, you need the diameter, length and incline angle of the pipe before you can predict.
If the flows of oil and gas were the same as the water and air, you do it the same way.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Been a long time...
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
