Piping Fabrication and Installation Plan
Hello AhliMekanik,
 On Sept. 14, 2008 you wrote,
AhliMekanik (Mechanical) 14 Sep 08 11:22
Hi pennpiper,
We are an EPC company that want to make a tie-in standard specification for our company. Maybe the title of this spefication will be divided, such as :
1) Design Specification for Cold Tie-in
2) Fabrication and Installation for Cold Tie-in.
Until now we do not have yet a project that having tie-in work, but we would prepare this procedure for our next project proposal.
I already sent you, Piping Fabrication and Installation Procedure. The outline of this procedure is :
- Scope
- Reference
- General
- Storing and Protection from Demage
- Preparation and Fabrication
- Welding
- Heat Treatment
- Assembly and Installation of Piping
- Examination
- Pressure Test
- Flushing
- Tables and Figures
- Appendices.
Thank you with your kind attention.
Best Regards,
Ahli Mekanik
Could you send me a copy of this procedure. I have a general work plan for piping fabrication and installation A/G and U/G, but am looking for something with more detail and content.
Thank you for you time,
 Joe
RE: Piping Fabrication and Installation Plan
I must confess that since your first posting (September 2008) I have not given this much thought.  I just assumed you had gotten the information you needed and had moved on.  My error.
Now, I must ask you:
Do you currently have a "Design Specification" for normal new project work?
And
Do you currently have a "Piping Fabrication and Installation Specification/Procedure" for normal new project work?
If so then I feel that these documents will also cover the issues related to "Cold Tie-Ins" when supplemented with the Planning guidelines I gave you in September 08 (see below).
Tie-In Planning (Activity - Responsibility)
1.    Identify each Tie-In(s) schematic location on P&ID - Process Engineer
2.    Review with Piping - Process & Piping Design
3.    Create a Tie-In Index (or List) with key information about each Tie-In - Piping Design & Process Engineer
4.    Review with Client - Process Engineer
5.    Go to the Field to locate physical point of Tie-In - Piping Design/Process
6.    Meet with plant personnel and review Tie-In requirements - Piping Design, Process, Plant Operations, Safety
7.    Discuss different types and configurations of Tie-Ins - Piping Design, Process and Plant personnel
8.    Establish physical Tie-In location point and type - Piping Design & Plant Personnel
9.    Define if the line can be shut –down, when, how long, draining, depressurizing, steam-out and other safety issues - All personnel
10.    Visually inspect the existing pipe.  Are more extensive tests needed to determine condition and suitability for the Tie-In - Piping Design and Plant personnel
11.    Mark or tag the selected Tie-In point - Piping Design & Plant Personnel
12.    Photograph the Tie-In point - Piping Design
13.    Draw sketch and take all required measurements - Piping Design
14.    Determine locations of all existing block valves, vents and drains - Piping Design
15.    Determine the location of all existing anchors and guides - Piping Design
16.    Based on selected Tie-In location and type determine if additional vents or drains will now be required - Piping Design, Plant Operations
17.    Include new vents or drains (if any) on sketch - Piping Design
18.    Insure that this process is followed for all Tie-Ins - All participants
19.    Get plant personnel to sign off on all data collected in the field - Piping Design & Process Engineering
20.    In the office modify the P&ID as required - Process Engineer
21.    Convert all field sketches into appropriate production drawings (Isometrics) - Piping Design
22.    Prepare a Plot Plan style "Tie-In Location Key Plan"
23.    Update the Tie-In List as required - Piping Design
24.    Review all Tie-Ins with Pipe Stress for effect on existing system piping and new system piping - Piping Design
25.    Finalize  (check, correct and approve) all Tie-In isometric drawings  -  Piping Design
Again, now every one who reads this and has been involved with Tie-Ins can add other steps based on there own experiences.  I encourage them to do just that.  It will only help.
