What does this mean?
see attachment.
RE: What does this mean?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
It looks similar to a weld symbol but that makes no sense in this instance.
I'm pretty sure I've seen similar before but can't recall the details.
Since it is a published standard I cannot post its contents.
Paul
Do you work with many ISO standards?
I think I'm clear it is to do with the edges,
but what does it specify? rounds? chamfer, burrs?
If the spec was in the corner of the symbol the permissable burr direction woud be unspecified.
Paul
Symbol Outside corner Inside corner
+ burr transition
- free of burr removal (metal)
+/- burr or burr free transition or removal
In your case (marked in red)= outside corner burr up to 0.1
The upper -0.1/-0.3 calls for no burr from 0.1 to 0.3. Removal (metal) is your choice.
