Locking BOM Row Heights and Column Widths
Hello all,
Has anyone found a way to lock the SW BOM row heights and column widths on the template?  I found some posts from 04' regarding the same issue so I was hoping that in the last 5 years there has been a fix.  I just talked the company into switching over from the Excel based BOM and now they are not so happy about the heights changing.
Thanks in advance,
BB
RE: Locking BOM Row Heights and Column Widths
BodyBagger,
We have used the SolidWorks BOM's for years now. The only time our heights change is if I grab them and drag.
What are you doing that makes the heights change?
Standing
SolidWorks Pro 2009 x64, SP3.0, PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
Hi Standing,
When we have a description longer than the description field it wraps the text and then changes the height of all the rows to match.  We would rather have it lengthen the description field as necessary if possible and never change the row height.
BB
BodyBagger
Attached is a Copy of our BOM.
Give it a quick try, maybe it will work for you.
Standing
