Helical Stairs
Helical Stairs
Can anyone point me towards a design example for helical stairs. The stair will only have support at the btm and top (concrete). I have looked at BS5395-2 but it seems to focus on the geometry.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Helical Stairs
RE: Helical Stairs
-You will need more stiffness in lateral direction.
-The outer stringer, being longer, has more moments in vertical plane and will deflect terribly, so provide sufficient stiffness
-Model the supports correctly. A small change in modellin the supports produces terribly different results.
-if possible determine the frequency, these stairs, especially if steel, tend to vibrate
-if possible, use steps to connect the two stringers and provide torsional stiffness that way, helps to cut down deflection and lateral bending
respects
ijr
