specify initial impact velocity
Dear All,
I am trying to set an initial impact velocity in modelling collision between two objects. I set BC/Velocity + instataneous. But the object moves at this specify velocity constantly (the velocity doesn't change). do you know why? or anything I did is wrong? Thanks a lot!
RE: specify initial impact velocity
Rob Stupplebeen
Rob Stupplebeen
