parts list defaults
parts list defaults
parts list defaults
every time i create a parts list i have to change all the settings, how can i save this as default?
(the save is greyed out, do i need different priveliges?)
RE: parts list defaults
%Program%\Solid Edge XX\Template\Reports\Draftlist.txt contains the Part lists settings. If you can't write this file, the save button is inactivated.
If you use ST2 (only) there is a new 'file location' in order to share the file on a network : Solid Edge Options > File Locations > Reports
Anthony
twitter : @totop
thanks
