flat pattern or smth else
Look at the attached file. this bended part is imported from solid works 2010. Is there any way to flatten it?
If I remove these "cuts" using syn.modeling with nx6, it is possible to get flat pattern. but it is possible to flat this model not removing "cuts"?
thanks.
nx 6.0.3.6 mp2 (testing)
win xp 32
thanks.
win xp 32
RE: flat pattern or smth else
use analysis -> one step formabilty analsis
or use from the (old)sheetmetall tools metaform
maybe have to create an planar face to flatten on...
give it a try
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
I tried to use sheet metal forming/flattening, but it gives me only curved profile, not a solid. Actually I need unwraped solid, with its profile.
As mentioned hundson888, maybe I should try wrap/unwrap geometry?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
