How can i asing a variable to this...
I just solve this, but how can i asing a varible " := " to this, so that i can use the value of "N"
And also, how can i reduce the number of decimals when i use the "solve", because i tryed using the "Format->Result->Number Format" and reducing the number of decimals doesn't work.
Thanks!
Diquan
Diquan
RE: How can i asing a variable to this...
Use the Given Find construct.
davidbeach: I don't know how to use the "Given" "Find" commands.
IRstuff: That's right and it did work, thank you.
Diquan
Diquan
Has this problem been resolved?
Mike
Yes, has been solved... thank you!
Diquan
Diquan
