How to run a single phase 220v 50 hz motor at 110 v 60 hz
I have a lathe motor from Europe which is 220v 1/7 hp 0.8 amp 50 hz. My supply is 110 volts 60 hz. I do have a transformer which can up the voltage to 220 but I am concerned about the frequency. Is there a frequency converter or vfd which can work?
Thank You
Thank You
RE: How to run a single phase 220v 50 hz motor at 110 v 60 hz
If a single phase VFD is fed from 60 cycles and the output at 50 Hz is fed to a wye:delta transformer, will the transformer be able to supply a 50 Hz motor?
If the transformer is connected to the mains the only issue will be derating by 1/3, however the current will be phase shifted on two phases. No problem on the grid but will a VFD be able to cope with a greatly different phase angle on each phase?
If the VFD can cope, this would supply a voltage and frequency that is suitable for the single phase motor.
Don't try to vary the speed very much on a single phase motor.
Don't use a starting capacitor.
Bill
"Why not the best?"
Jimmy Carter
Probably it would work. You would need the transformer however.
Bill. I'm not sure.?
Keith Cress
1) If you want to do it with only a transformer, you need to keep the V/Hz ratio the same (or at least within 10%). So if you REALLY have a 220V 50Hz motor with a 4.4:1 V/Hz ratio, to run it on 60Hz you would need 264V. Then it will simple run 20% faster. To get 264V from a 110V supply (although it's probably 115V) you need to use a transformer with a 2.4:1 turns ratio, that will be hard to find. But before going off half-cocked, don't assume anything, measure your actual voltage and read the actual nameplate of that IEC (European) motor first.
2) If your IEC motor is 3 phase (you need to check), then I would instead buy a cheap little VFD that accepts 120V input and provides a 240V 3 phase. They are out there, no need to step up the voltage, it does so internally (on the DC side with a voltage doubler for those who don't know). Then you can program the VFD to provide the EXACT voltage and frequency that you read on the motor nameplate.
3) If it is a 1 phase 220V, 230V, or 240V IEC motor, go back to the transformer method and live with the higher speed.
4) At that small of a HP rating, there is a chance it is a DC motor, which means you have a DC drive on there already and input frequency may not be relevant at all. But again, it all depends on what you really have.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Keith Cress
Keith Cress
