Design of external gear pump
I have been assigned to design a external gear pump. It would be great if anyone provide a step wise procedure in design of external gear pump.
RE: Design of external gear pump
External?
My experience has been that they actually work better with the gears on the inside.
SNORGY.
That said...
I would start by scouring everything you can find out about Viking Pumps.  There is lots of good information about them and their product out there.
SNORGY.
Someone else trying to re-invent the wheel again laughtears.
SNORGY.....
The difference between internal and external gear pumps can be found here:
http://en.wikipedia.org/wiki/Gear_pump
In my opinion, somewhere in the third world, the terms "design" and "specify" are interchangable.... this leads to confusion on these fora.
-MJC
