Modeler error NX4
Modeler error NX4
Modeler error NX4
I am trying to create a section view from a revolved model.
I've tried most of the corrective actions in the detailed description, and have a hunch that there is something wrong with the model. But it's not anything immediately apparent.
Any ideas?
RE: Modeler error NX4
There's nothing apparent to me either but that's because there's simply nothing like enough information provided to be able to tell. Without a part file or even an image of what you're attempting it is impossible to say more than that they work for everyone else most of the time.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
A search on the GTAC solutions archive revealed that the error is due to a bug in the earlier versions of the Parasolid kernel.
Subject: [PR-01533455] can not create section view - modeler error
The problem occurs in all versions of NX4 /NX4.1.3 / NX4.0.2.2
***** <<<<< This PR has been closed.  The resolution was: >>>>> *****
The problem where there is a modeling error when trying to create a section view is fixed in Parasolid Versions 18.01.197 and 19.00.111 which will be in NX5.0.1 and NX6.0.
Thanks. Just what I was looking for.
