CODE REQUIREMENTS FOR SITE RAILINGS
3
While I have seen numerous publications (IBC, ADA, etc) for the requirement of railings for building construction, I know of no such codes, guidelines or industry standards for railings for exterior/site applications such as headwalls or retaining walls.
In the past I have used "judgement" when calling for railings.
Does anyone know of any railings codes or standards for exterior site applications?
Thanks in advance for any feedback.
LAH
RE: CODE REQUIREMENTS FOR SITE RAILINGS
The guidelines I've read about for exterior deal with sidewalk and pedestrian ingress/egress.  For retaining walls and headwalls like you I've just used common sense.
Here in Texas if a sidewalk has more than an 18" drop off the side, you need a rail there.
For any stairs with more than 3 risers, you need a handrail on both sides. (or at a minimum separation in the case of very wide stairs)
For any ramp with a rise greater than 6-inches you need handrails on both sides, unless it is a curb ramp.
