Format for new sheet
I currently have a template that consists of 2 sheets, each with a different format applied. Whenever a new sheet is added it automatically inserts the template from the first sheet. I know how to go to page setup and change that but I was wondering if there was a way of changing it so that when I insert a new sheet, it automatically uses the format on sheet 2 instead of that on sheet 1. Does anyone know how to change this so that the second format is used instead of the first?
RE: Format for new sheet
