Transformers& overcurrent protection
On a current project I have an electrician that has questioned my circuit breaker sizing on the primary and secondary of a dry transformer. The engineer i work for said that my breaker sizes were correct,however, the electrician's vendor says the breaker is oversized. Is there an industry standard for overcurrent protection on transformers?
RE: Transformers& overcurrent protection
If you are in the US, I expect that would be the NEC.
Alan
Check into NEC 450.3 & 450.4.
