portal frame bracing
I usually use CHS or SHS as bracings in our portal frame buildings, i would like to explore using crossed angles and/or crossed flats. are there any pitfalls i should be aware of?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: portal frame bracing
2. angles and rods have limited spans that can travel before deflection become an issue (to solve this you can hang from the purlins)
3. I prefer rods over angles due to the ability to have a turnbuckle for installation.
4. getting angles to the right length such that they are installed correctly is hard. often they are too long this causes a compression that needs to be taken up before they can be used as the tension tie.
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that they like it
