Hydrotesting / Pneumatic HTesting
thread378-235027: Pipe testing - Air vs water testing
Alot has been said for the dangers of Pneumatic Testing compared to hydrotesting.
Due to the serious consequences that may erupt during pneumatic testing, is there a way that we can protect testers due to a possible eruption or explosion?
Such as for cylinders limited in size, can we test the cylinder to the required pressure (say 600 psi) with Nitrogen while being inserted in a pail of water or other. What would be the effects if the cylinder erupted and failed the test?
Or, without the use of a water barrel, can we utilize an open ended container (preferably see through) and insert the container within and conduct our pneumatic h-test?
RE: Hydrotesting / Pneumatic HTesting
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
I would check the Cylinder Gas Association site for some information. If you are near a Scuba Dive Shop you might check with them for their codes as they still check dive cylinders under water.
A little guidance from Catalina Cylinders with references in the information presented.
http://www.catalinacylinders.com/index.html
http://www.cganet.com/
It would be best while filling the canister to visually identify any leaks or other during the test.
