Dominant Peak at 6 times RPM
I have a problem with a dominant velocity peak at 6 times the rpm. What symptom does this indicate. This peak is on the NDE of a 400 kW Booster fan. The fan uses journal bearings. The DE of the fan shows 2 times rpm vibration but on the motor DE there is no indication of 2 times which would point to misalignment.
I need help with the 6 times component. And also whether taking measurements across the coupling should both have 2 times component to point to misalignment. Thanks.
RE: Dominant Peak at 6 times RPM
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
On the discharge side however, there is an extra small mechanical (screw-like) support rod, type that looks like adjusting rods for accelerator linkages on old heavy trucks. No one has ever touched it though, even during shut-downs. I have attached a photo, dont know if it will be any help. Please let me know about the picture. I can always get another one.
Thanks GregLocock.
Johnny Pellin
I dont understand when you say "fan running pinched back at low flow"?
Johnny Pellin
Why do you think the sixth harmonic (300 hz) is dominant?
Cheers
Greg Locock
On the Horizontal measurement you have a big spike at 50 Hz bigger again at 100 hz, and then a descending series of harmonics. No way would I describe 6th order as dominant.
The sixth order is just part of the harmonic series which I suspect is based on 1st order , 50 Hz.
Have you balanced the fan recently?
Cheers
Greg Locock
Where is the evidence that this is a 6th order vibration problem? Your graph in your first post does not show "domninant" 6th order vibration.
M
Dr Michael F Platten
Brought it down from 35m/s2 to 4m/s2.
Unquote
If correct, your vibration units are in terms of acceleration, so you've balanced it from nothing to less than nothing.
The data you show doesn't indicate a problem: an overall amplitude of <6mm/sec pk is OK. Take any machine vibration spectrum and, look hard enough you will find things that cannot and do not need to be explained - they just are!!
Can you explain your concerns a little better?
could be worse!! Could be me. ;)
