Changing SWBOM Column Headers
I have tried and searched but no luck. I need to change the column headers for the SWBOM but am not having much luck. ITEM NO. should be NO. and PART NUMBER should be PART NO. Where does SW pull those default headers from?
RE: Changing SWBOM Column Headers
The 'behind-the-scenes' properties being referred to in the columns are the SW defaults.
I did try that before asking the forum. I changed the titles and then saved the template (overwrite). When I brought in the table it did not save the changes.
make sure you can see the new template in the "Table Template" box in property manager while inserting the new BOM. If not change the file location or add new file location in options.
Eric
The setting from that thread is working for me and this seems to be a different issue.
OK, it is now working. For some reason when I saved the template as a new file rather than overwrite it works fine. Thanks to all for your help.
BB
Are you sure you are inserting the correct BOM? Try saving the BOM template as a completely different name and make sure it is the one being referenced.
