History Tree Font Size
We recently switched our Catia V5 R18 from unix to windows. When we made this change the history tree has small fonts. Is there a way to increase the size of the fonts? Thanks in advance.
RE: History Tree Font Size
Don't know if I understod the question.... activate the tree by clicking the white branches (think shift+F3 also works) and zoom with mouse to resize the tree...
Control + scroll wheel on mouse for zoom of tree (with standard mouse settings). Not sure if that helps you out or not.
Just a comment to Azrael's reply. A bit on the side, I know, but I think you'll find this useful: Deactivate the 'Zoom on tree' option in "Tools > Options > General > Display > Tree Manipulation > Tree zoom after clicking on any branch" and use crenner280's approach to zooming the tree. Accidental clicks on the tree, especially when you try to expand your tree nodes, combined with a space mouse can send your tree off the screen or make it so small you think it's gone for good...
If you still need to zoom on the tree after deactivating this, you can still do just that by clicking the small axis widget in the bottom right hand corner. Click it again when you've finished zooming on the tree. Or Shift+F3 like Azreal says.
Christian Bunes
http://www.plastal.com/
