Polyphenylene Sulfide (PPS) Question???
I'm struggling to find what effects Sulfide has the polymer PPS. The only information that I can find is comparing PPS with PPO (Polyphenylene Oxide). I understand the properties of PPS, such as thermal stability, chemical resistance, viscosity, and flame resistance, but what effect does Sulfide have on those properties. Thank you!
RE: Polyphenylene Sulfide (PPS) Question???
I don't have detailed knowledge of the exact structure of the polymers you mention, and that aspect is not my real area. I am more an applications guy.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Fox Manufacturing Group (Machining and Molding)
Don't focus on the chemistry but what the material can do for you. Compare its properties to other polymers free at www.matweb.com
P.S. I have a PhD in chemistry which makes that comment even funnier
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
[url=http://tjmain.com/foxmfggroup.com/Home.html]Fox Manufacturing Group (Machining and Molding)[/url]
