BS EN 10026 S276
BS EN 10026 S276
Hi all,
Hope you can help me.
Does anyone have the following standard to hand or know of an equivalent:
BS EN 10026 S276
The part in question is a parallel flange mild steel channel, 200x90x30. I realise that the properties are likely to be similar to standard mild steel, but require more detail.
Any data (main standard, suffix or both) would be gratefully appreciated.
Best,
AS
BS EN 10026 S276
Best,
AS
RE: BS EN 10026 S276
I have jus searched for your document at this site:-
http
it didn't find that number.
This link shows material strength for BS EN10025 S275 again there appears to be no reference to S276
http://www
I wonder if someone as given you the wrong number?
desertfox
