Machined surface color
I want to highlight machined surfaces by altering their color.  I'm editing an existing model that already contains several highlighted machined surfaces, but I cannot figure out how highlight new machined features.
How do I change the color of machined surfaces?
Best Regards,
hpon
hpon
RE: Machined surface color
You need to change the selection focus from Solid to faces/surfaces.
Ben Loosli
Hi Ben,
I can select the surfaces.  But I would also like to permanently change their color, so that all machined surfaces are gray and all non-machined surfaces are green (not sure if that was clear from my post).  Is that done by changing the selection focus?
Where do I change the selection focus?
/hpon
hpon
I got it now.  Thanks.
hpon
What I do is go into insert mode after the cast part is merged in and change all solid surfaces at that point to a color. Then any subsequent cuts would be the default color of the part.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
