Postbuilder operationname and sequencenumber
Hi Everybody, is it possible to create a pb-command that would give me the possibility to collect all operationnames, active tool number and sequence number and write this as a list to the beginning of the NC-file. It should act a little like the toollist PB-COMMAND that can be imported, that actually writes the tool-info to the beginning of th NC-file. This would be very helpfull for the operator for fanuc-GOTO option if necessary. Maybe some good tips out there in the field?
Thanks in advance, Bert
RE: Postbuilder operationname and sequencenumber
For seq no's are you looking to fix a number to each operation? I usually just use seq no's at each tool change with N = mom_tool_number. Makes it easy to search.
Bill
Get help about the usage of this command in shop doc files located in \MACH\resource\shop_doc
AK
NX 3.0.5.3
