Scrambled Spreadsheet Images
Has anyone ever run across the problem where visually one spreadsheet image is superimposed (partial image) over another spreadsheet in the same workbook? It goes away when you scroll the partial image off the screen, and then scroll back again. Seems like it's maybe a refresh problem.
RE: Scrambled Spreadsheet Images
TTFN
See this blog post about the effects of a recent update:
htt
(I haven't seen this behaviour myself)
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Call me a naive optimist, but I'd like to think that December's corporate updates will fix it.
He also told me that he had tried to reproduce my problem on several other, supposedly identical, computers. The problem did NOT occur on those other computers. So his conclusion is the the problem is caused by some sort of interaction between the latest patches and some aspect of the way I am running my computer.
If it wasn't for Eng-Tips alerting me to this being experienced by people other than me, I would have wasted the last fortnight trying to work out which of the last minor changes I made to the spreadsheet had been the cause of the problem.
In some recent testing, I did discover two more things.
(1) If I disable macros when opening the troublesome spreadsheet, the problem does not arise.
(2) My spreadsheet, being intended to be run by the target readership of the "for Dummies" series of books, usually runs with protection set ON for all worksheets and for the workbook as a whole, a state that is partially enforced by activating this protection through the Workbook_Open event handler. In this state the problem does NOT happen. It requires that I set the protections to OFF (my usual state when maintaining the spreadsheet) for the problem to raise its ugly head.
And I have found that the quickest way to get the screen showing the correct way is to activate another sheet then go back and activate my sheet of interest immediately afterwards. It is less work than scrolling the screen up then down.
Ahramos. Does what you are experiencing match this?
TTFN
After a heap of playing around, I have discovered that all the spreadsheets that exhibit the problem use "dynamic named ranges". If I simply (but laboriously) convert these to static named ranges the problem disappears. Of course, the spreadsheet then becomes completely useless, but that is beside the point.
This presence of, and potential removal of, the problem applies whether the dynamic named ranges are constructed using the OFFSET function or the INDEX function.
So, the problem seems to have revealed the following characteristics.
» The spreadsheet must be unprotected.
» The spreadsheet must have macros, with those macros "enabled".
» The spreadsheet must use dynamic named ranges.
» The spreadsheet must have a large amount of data (whatever I might mean by "large").
» Microsoft's latest updates must have been installed on the computer.
» Even if all the above conditions are met, the problem will occur on some computers yet not occur on others that seem to be identically configured.
Does anyone out there have any experience, or is anyone prepared to run some tests, that confirm and/or contradict and/or supplement the above characteristics?
It seems that, in my case at least, the reversal of the single Office update
"Security Update for Excel 2003 (KB973475): EXCEL"
is sufficient to get rid of the screen scrambling behaviour.
