Definition of repair
Dear all, do you know where I can find the definition of "repair work" according to ASME code?
On a vessel (after PWHT) due to a fabrication mistake I have to remove up to 3 mm of material from the raised face of a 10" flange, is this considered a repair work according the ASME code?
after the machining work do you suggest to repeat the UT of the flange?
PS vessel is not U stamped
Thanks in advance and best regards
RE: Definition of repair
There is no formal definition of repair work type in ASME B&PV Code. You have either base material or weld defects along with misalignment or tolerance problems which are dealt with by welding or other forms of re-work.
The above are called conformances and should be dealt with according to the Certificate Holder's QA program.
No. I would suggest a surface LPT of the machined surface.
Dear Metengr
thanks for your reply.
