equivalent pipe method
i used the equivalent pipe method to determine the head of the pipe. the pressure drop across my device is known and is converted to head. now i have the total head of the system. to fall within the recommended pressure operating range of the device do i add head before selecting a pump?
RE: equivalent pipe method
Please take some time to explain what you are trying to do and what you have done so far.
Care to try again?
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
When in doubt, going back to the basic Bernouli's equation usually helps.
By the way, because this board gets a multiutde of people from around the world, all coming from different disciplines, communications skills are very important. It really helps us to help you if you:
(1) Use proper grammar, puncuation, capitalization, and spelling;
(2) Provide a diagram if at all possible (that overcomes any deficiencies in (1);
(3) Give way more detail then you think necessary, so no one is left guessing.
Big Inch -- I'm not really sure what he's talking about either. It sounds like he wants to add a head fudge factor before selecting his pump and is looking for someone to give him an ok.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
