Lock dimensions
Lock dimensions
How do I lock dimensions? I found http://www.eng-tips.com/viewthread.cfm?qid=185706, but not the "right-click menu" that is mentioned in the thread.
Wildfire 3.0
/hpon
Wildfire 3.0
/hpon
hpon
RE: Lock dimensions
Select the dimnsion you want to lock and right-click the mouse. There, you will see options including "lock".See picture
RE: Lock dimensions
Unfortunately, no menu comes up when I do that. I have noticed however, that the defined dimensions stay fixed so long as I don't drag any entities, -if I do, everything starts floating around. Editing dimensions by typing in numbers works fine.
I recognize the fact that I'm new to this software and that I'm not using the newest release, but the interface sure strikes me as very non-intuitive and out-dated for being such a renowned work-suit.
/hpon
hpon
RE: Lock dimensions
Home of user beta testing (F00 release).
Easy to remember the call center number: 1-8004PTCHELL
Ben Loosli
RE: Lock dimensions
Michael
RE: Lock dimensions
Make sure the dimension is selected (left-click) it should become red, and then R-click.
