Where to record values on VFD Circuit
Hi there,
I am trying to determine the actual Kw cost of a motor being run via a VFD.
Where is the best place to measure the values I and V as there is differnces on the incoming supply to the load side of the VFD?
Thanks in advance.
Thomas
RE: Where to record values on VFD Circuit
Since actual kWh cost, not kW cost, is measured on the line side, that is where to put your kWh meter.
Measuring V and I won't help much. Nor will measuring kW. Unless it is very constant over time. Cost is energy based and that is kWh.
Gunnar Englund
www.gke.org
