Gas flow rate calculation
I am trying to do a calculation....
I have a gas line 10mm and approx 100m long. The pressure in the line is 7 bar when the outlet is closed and is maintained at 7 bar by the supply gas system (gas bottles) when the outlet is open.
How do I calculate the flow rate when the outlet is fully open at the end?
RE: Gas flow rate calculation
You need to know 2 of 3 basic parameters for pipe flow work.
1) inlet pressure
2) outlet pressure
3) flowrate
From your description I think you're saying that the inlet pressure is maintained at 7 bar (but I don't know if its absoute pressure or gage pressure) and the outlet is maintained at atmospheric pressure.  I'll assume pressures are in BarG and make that 7 and 0.
Now see the tutorial on gas flow equations,
http://www.psig.org/papers/2000/0112.pdf
And check your answer here,
http://www.lmnoeng.com/DarcyWeisbach.htm
Note the 40% pressure drop limitation.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Remp,
What BigInch has stated is correct.
You may also use the Renouard equation:
pi^2 – po^2 = 46742*rho*L*Q^1.82*D^(-4.82)
where:
pi = pressure on the start of pipe line in bar
po = pressure on the end of pipe line in bar
rho = relative density
L = length in km
Q = flow rate in m3/h
D = pipe diameter in mm
