Relay drive for -12V and GND controlled with the positive voltage
Currently I am adapting some additional modul to the existing design with dual +12V and -12V supply were the +12V is no more sufficient enough to drive the 160 mA power relay I need, so I would like to use -12V and GND to energize the coil. For driving the switching component I have 12V and 0V for my disposal from CMOS logic. For this reason I would like to ask you if you have some real word proven circuit able to solve this problem. My first ideas are to use P channel JFET driving MOSFET or using inverting OPAMP with -1 gain driving NPN bipolar transistor ( -12V on C and 0V on E ) but before eventual reinventing the wheel I would like to know the opinion of someone with more experience in electronic design than I have.
RE: Relay drive for -12V and GND controlled with the positive voltage
Are you saying you want to run the relay on your -12V supply?
What signal are you going to control this relay with?
Keith Cress
Benta.
Keith Cress
Keith Cress
Sorry.
Carry on.
Keith Cress
