assembly drawing problem
im having a problem with assembly drawings. i have assembled a mould where i created cavity and core with subtracting product through linking it to plates.
product outer edge was created with revolved command. i have revolved studio spline with a 1mm offset to get the product as showed in "product" image. in the product drawing it shows all edges correctly.
but in assembly drawings as in "assm drawing" image.. outer edge is upset. some times when i update the drawing it automatically corrects itself. but then when close and reopen it.. its upset again.
i have tried loading product manually before opening the assm. and unselecting load assemblies partially option. nothing worked. im using NX6.
pls need help on this.
all the other curves are displayed correctly.only this edge has the problem.randomly it correct itself sometimes.
RE: assembly drawing problem
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
if so how to turn it off?
how can i try a smaller drawing tolerance???
sorry im little new for this.
As for the display tolerance, select the View, press MB3, select 'Style' and under the 'General' tab you'll find an entry for 'Tolerance'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
even with old upset tolerance. i tried a prient out. print showed edges correctly. it seems like just a visual problem.
thanks a lot for the help. :)
