Need help in designing a ring-type load cell !!!
I know help designing a ring-type Load cell sensor/transducer system, with a certain parameter for the ring and with commercially use transducer. The system has to be capable of measuring a load from 0-1000N with an output of zero to 10 volts or +/- 10 volts.
Thanks for the response.
RE: Need help in designing a ring-type load cell !!!
Ed Danzer
www.danzcoinc.com
www.dehyds.com
h
Any reason you can't buy a standard one?
As Ed said, more info is needed. Any off-axis loading? Off-Axis cross talk limitations? Compression (or tension) loading only? Stiffness requirements?
