Pressure Relief Valves
Somewhere in code, I know I've seen it, there is a section on recommended practices for installation of Pressure Relief Valves.  It recommends a certain height for relieving hot liquids and steam/condensate so that when it reaches ground level it no longer is hot enough to cause a safety hazard.  Can anyone help me locate this or give me the rules of thumb?
I seem to remember that from 160-180*F the relieving heigh was somewhere around 22-24 feet.  I'm looking at relieving 150*F liquid.
RE: Pressure Relief Valves
The ASME B31 Pressure Piping Code provides the
standards and requirements for pressure relief devices.
David Baird
Sr Controls Designer
EET degree.
Journeyman Electrician.
Yes.  I have B31.1 and 31.3.  However, I also have the full pressure vessel code.  I can't find the section I'm looking for.  I've read the whole thing, awhile ago.  I remember seeing something on recommended discharges.  I can find all of the discharge information on location, direction and support; but I can't find anything on height.  I'm pretty sure I saw it there or in some other training material and I can't find it.
mrsongs-
Perhaps you are thinking of VIII Div. 1 Appendix M?
jt
API 520 Has information
AA
