Font in text extrusion
I am extruding text into the face of a part using the text sketch entity command. It seems that the text does not change when I switch from standard to bold. Anyone know why? I do get a change if I switch from standard to italics.
I am using arial narrow font if that makes any difference.
Kevin
Kevin
RE: Font in text extrusion
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
I got sick of searching for Fonts so I made a simple Word file called Fonts_Tabled that I can use to track down fonts with.
It's a lot easier to look at then it is to open the font setting in CAD make a change and go back and forth.
Remember that you need to select the Points Radio button to select # pixels height is the default.
Michael
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
