Purging section views from custom template NX6
I've made a template that once had drating views with sections. I've cleaned the part file out and used part clean up.
But when I make drafting views in parts based on it it starts at sec C-C instead of A-A.
how do I clean this out of the template??
TIA
Dave
RE: Purging section views from custom template NX6
In the drafting application go to Preferences -> View Label...
Hit the 'section' button at the top then change the letter to 'A' at the bottom. You could also try out the 'default' or 'reset' buttons, but these may reset other options that you do not want reset.
That was it,,, thank you!
