FloXpress - not so fast
I mean, not so fast getting started.
First, I had to make a model that was seamless.
Okay, that's out of the way.
Now, I'm trying to specify the inlet conditions.
But with the >required< caps in place, I can't seem to tell FX what face is to be the inlet face. I keep getting the message "The selected face does not contact the fluid or it is external face of the model."
... and that's as far as I got.
The help is abysmal even by SW standards.
Anyone?
SW2009.4.1
Anyone?
SW2009.4.1
Mike Halloran
Pembroke Pines, FL, USA
RE: FloXpress - not so fast
Got it. Okay, stumbled on it.
You have to HIDE THE MODEL so you can click the face of the plugs. I think that's just a little counterintuitive.
Mike Halloran
I am using a trial of FloWorks and it is defiantly a whole bunch better. You can actually view your mesh!! I am not sure if I would ever trust FloXpress for any real project because you barely know what is going on in the background. I did find that if you adjust the "Smallest Flow Passage" it does indirectly affect the mesh. So I used that for my sensitivity studies. I hope this help.
Rob Stupplebeen
I was mostly interested in a rough delta P, which is not reported, to see how much of the backpressure budget is consumed by the one part.
So I ran it with a not quite arbitrary flow, the nominal system flow, which reports a velocity.
Then I ran it with a not quite arbitrary delta P, the system backpressure limit, which reports a considerably lower velocity.
I think I can safely infer that the part is too damn small.
Color me disappointed. The 'report' produced by FloXpress is not nearly zoomy enough to make a case for nearly doubling the cost of a seat.
Mike Halloran
Joe Hasik,
CSWP/SMTL/MTLS
SW 09 x64, SP 4.1
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
I'm saying it's not strong enough to catalyze an up-sell.
Not here anyway.
Mike Halloran
With FloXpress you basically have to completely black box your analysis because of limited reporting tools, mesh viewing, refinement and inputs. In a magic 8 ball at least you know your odds.
Test and correlate often if this is for anything critical.
Rob Stupplebeen
